Bearing replacement Raymarine wind
Albert Ross
14 Oct 2004
Troon and beyond
Hi, The bearings in my Raymarine ST60 wind transducer are shot. To get them out, I have opened the egg shaped end of the wind transducer .. now I need to get the circuit board out.
Any suggestions how to get it out without breaking it?
Not in the Owner's Manual is it? (I suppose it is a bit too technical for that?)
https://www.sv-zanshin.com/r/manuals/raymarinest60windownersguide.pdf
CA11] E28081 Wind Transducer Service Kit Instructions
https://forum.raymarine.com › showthread
7 July 2016 · 10 posts · 2 authors
I received the service kit for my ST60 windvane unit. The kit had the parts and allen wrench but contained no instructions and I could not ...
[CA11] ST60 and ST60CH issues with new wind vane 4 posts 23 Oct 2019
[CA11] ST60 Wind Troubleshooting Question ... 6 posts 15 Mar 2020
Masthead Wind Transducer Test - Raymarine forum 1 post 30 Nov 2018
DG11] masthead repair - Raymarine forum 5 posts 25 Jan 2019
The PCB is only a push, slightly clipped, fit and the egg holds it in. Mine has 2 small holes in it ... gently lever it out with a small screwdriver or similar. Be careful not to strain the little 5 wire connector ( which can be carefully disconnected as well if necessary). Theres a lot of good stuff on this forum about revamping these units.
