Yeoman_24
I have recently removed my old Whitlock (?) steering binnacle from my Moody 30 with the intention of changing internal bearings. I have read the really good steering overhaul in the tech section but my binnacle is even older still!
I am coming across the usual galvanic corrosion problems with S/S machine screws and aluminium. I am going to use a 250v heat gun, wd40 and an impact driver unless anyone can advise anything better?
Has anyone worked on one of these really old systems or and advice will be gratefully received!
Question 1 - How long can I apply the heat for? (heat gun novice!)
Question 2 - Pic 1 shows the inside of the top of the binnacle and pic 2 shows the underside. I think I’m going to have to get all 8 bolts off to ‘lift off’ the binnacle top as the bearing is housed it it and held down by a ‘lip’?
Question 3 - the base looks like it is a bearing housing but there appears to be no way to remove it. (I’m going to use paint stripper to see if there are any machine screws which have been painted over).
Question 4 - There is a ‘collar’ at the base of the main pedestal upright, just above the base section. Should I be looking to do anything with that?
Below is a cross-section of the nearest I can find on the internet (Cobra 2ER)
Cheers.
Cheers.
