NeilPayne
New Member
Can anyone tell me the ideal location for a waste holding tank on a 1997 Bavaria 38, 3 cabin 2 heads option?
Tranona,You may have difficulty in finding a good location for the tank from the aft loo as there is unlikely to be room in the aft cabin because all the space is taken up by the water tank. My 37 has a very similar aft loo, but there is space in the locker behind the vanity unit where the water pump and valves are. These have to be moved, but there is room for a good size gravity tank there - mine is 65 litres.
As I said, the factory fit tank was under the saloon settee just behind the forward bulkhead, which is OK for a forward loo, but means you have to run a 38mm pipe all the way across the boat for the aft loo. An alternative might be under the forecabin berths, but that is difficult if you have the second water tank there as the only space left has the transducers in it and you need access to those.
Quite normal to only have holding tank on one loo because of the complexity of pipework and space limitations to fit a tank capable of servicing two loos. In the latest boats (not just Bavarias) loo compartments have been redesigned to create space for a gravity tank, usually under the sidedeck or in a bulkhead locker, but clearly not possible on an existing boat.
