Battery Wiring/Configuration
Frayed Knot
3 Nov 2011
Suffolk - Home and boat
I’m currently (!) in the planning phase of installing a new Lithium battery bank. There will be either three or four batteries (depending what I can best fit into the available space) in parallel. I am now wondering if, instead of the usual “daisy chain” + - + and - to - links it would be ok to connect all to centrally positioned, common pos and neg bus bars, which would then allow neat connection points for the various take-offs etc.
VicS
13 Jul 2002
That is one way of doing it.
You might like to read SmartGauge Electronics - Interconnecting multiple batteries to form one larger bank which describes ways of connecting multiple batteries to form one bank without introducing uneven voltage drops .
There are many other useful items to read on the "technical Info" tab on the Smartgauge website.
PaulRainbow
16 May 2016
Suffolk
With multi battery Lithium installations it's generally considered better to connect them to busbars. Each battery having it's own fuse and isolator.
Baggywrinkle
6 Mar 2010
That's often exactly what you find in the Victron Schematics ...
Their schematics pages are a mine of useful information, much of which is also relevant to any system. System schematics - Victron Energy
e.g.
.... but make sure that all the positive cables to the positive bus bar are the same length, and that all the negative cables to the negative bus bar are the same length. Every battery needs to see the same voltage drop in the cables or each battery will be at a slightly different voltage. It's what I'm going to do with my Lithium install too.
PaulRainbow
16 May 2016
Suffolk
That's often exactly what you find in the Victron Schematics ... e.g.
Spot on (y)
Frayed Knot
3 Nov 2011
Thanks for the advice and info (which I’ll study tonight)
Although a completely fresh/all blue installation would be ideal, as I have good quality mains charger, alternator to battery and MPPT controllers in place, all of which have lithium and/or customisable charge settings I can’t justify that expense.
I’m probably going to settle on either Fogstar or Renogy batteries. I’m tempted by a single Fogstar 460 which would fit the space perfectly but there’s the “eggs & basket” consideration.
As to what I’m linking Paul, I was really just talking about the outlet to the distribution board, common neg. plus the charge cables & monitor.
I was unaware of the cable lengths issue so extra thanks for that, which also means a bus bar makes a lot more sense.
Having come up with an idea which is actually the correct way to do it, I’m not sure if that means I’m cleverer than I thought I was, or something less comforting.
Frayed Knot
3 Nov 2011
