Battery types explained in plain words
Spi D
25 Jul 2011
Denmark
I might be facing a replacement of a domestic 105h battery (fully charged, dropped almost completely after running 2x15w lamps for 12 hours).
I do have experience with more types, makes and models and also know my preference, but browsed the web to see if anything truely fantastic had been invented.
Not so, but I stumbled over this article that I agree with:
Sterling Power Products on their homepage: said:
What is the best battery to use for an auxiliary charging system?
I keep getting asked this question all the time, when being asked which is the best battery. I refer to marine or vehicle auxiliary charging batteries or domestic batteries. To say there is a lot of confusing literature about this subject would be the understatement of the year. The information in the literature tends to be correct, but it's the bits which are not in the literature and the customers' assumptions that cause the confusion and hence the problems. I will try to answer the question. But in order to save you time, I suggest you adopt the following attitude and make the person trying to sell you these things answer the questions below.
The key question
Another way to approach this subject is the simple Irish way (being Irish myself). I went onto the web and obtained 3 different battery type prices, these were the first prices I came to and have no reflection on any company. I was looking for about a 100 amp hour battery.
100 amp hour leisure. Normal open lead acid (so called leisure) £49.99
100 amp hour AGM = £175
100 amp hour Gel = £265.59
So in my simple mind the AGM is about 3 times more expensive than the standard one. And the Gel, about 5 times more. So the question is; if these batteries are 3 – 5 times more expensive than the standard one, what do they do that is 3 – 5 times better? Do they last 3 – 5 times longer? (I think not, more like the reverse). Do they charge 3 – 5 times faster to reduce your engine running hours? (Only in their dreams.) So rather than ask me weird questions; please ask the sales man, who is trying to sell this stuff for cycling, exactly what you are getting that is 3 – 5 times better than standard lead acid batteries. Then please let me know as I could do with a good laugh.
The brutal truth about marine leisure batteries
There is no such thing as a marine battery. If you see a marine label on a battery it is simply words and may as well say Mickey Mouse.
For cost and performance open lead acid batteries are king. All other batteries are a derivative of this, with variations to suit different markets, where there are specific problems implementing the standard lead acid battery. E.g. Gel, is a standard lead acid battery except that the acid has been transformed into gel. But by solidifying the electrolyte, you introduce many problems not associated with free flowing water based batteries.
“Most expensive is best” This is so not even close to being true. In fact I would say the reverse is true in the marine leisure market. When reading all the sales literature regarding Gel/AGM, please note that none of their curves and claims refer to standard lead acid batteries. (They know better). They never claim they have better performance than standard open lead acid, this is just an assumption on your side. They claim weird things including longer shelf life and that you can turn them upside down and have your dinner under them. Who cares? I want fast charging, long life, plus good value for money from my batteries. I don't want to sit and watch them on a shelf for a year and have my dinner under one.
If a statement says that this is the best battery. The question is, best at what aspect?
If the term 'maintenance free', is on a battery, then treat this with caution. There is no such thing as maintenance-free, all batteries are basically the same. A Gel, sealed lead acid and AGM are all only maintenance-free because of the reduced charging performance curves; and not because there is something special about the battery. If you charge a normal lead acid battery to the Gel or AGM curves, then they would not require maintenance either. Remember 'maintenance free' is a handicap to fast charging not an advantage. This feature, which on the surface looks good, is, in most cases the worst feature that you could possibly buy; as this feature dramatically limits the maximum charging characteristics of the battery.
Fast charging costs water, i.e. if you want to charge you batteries fast, don't touch a Sealed/Gel/AGM etc with a barge pole. Fast charging will result in a certain % water loss from the battery. If the battery is sealed the water loss cannot be replaced. REMEMBER FAST CHARGING AND SEALED/MAINTAINCE-FREE ARE A CONTRADICTION OF TERMS. You may not like this, but tough, it's the way it is.
Watch the term leisure / deep cycle as it simply does not exist. The standard, so called, leisure batteries, are simply starter batteries with extra support for the active lead material. This may increase the life by 5 – 10 %, but does not turn a starter battery into a deep cycle battery. True traction (deep cycle) are not available at a sensible price and are uneconomical to use for standard leisure use. However, if you plan to live onboard or travel the world then do look at 6 V or 2 V traction and build your battery bank up from those batteries, but expect to pay about 3 – 6 times the price of so called standard leisure batteries. On a daily use cycle, the standard so called leisure battery (which is a starter battery) will last you as little as 6 – 8 months whereas traction would last 15 years. But on a leisure rating (2 weekends per month and about 4 weeks’ holiday) then you would get about 5 – 7 years out of a standard leisure. That's if you charge it right using advanced regulators and constant current battery chargers).
Battery sales companies quote battery cycles such as 6000 cycles for the battery. This looks good on the surface, however it will be 6000 cycles at say 10% discharge. This is a meaningless figure. All batteries have a manufacturers' graph, which odds are, you will not see in full; as the embarrassing section tends to end up on the advertising company’s editing floor. The graph will have % discharge on one side and cycles on the other. This graph is sometimes shown on glossy battery information, but is normally censored at about 30 – 40% discharge, where the figures can still show 4000 cycles. What they fail to show is the 100% discharge cycle (which they of course say you should never go to and I am not for one moment suggesting you should). This, at the end of the day is the only ultimate datum point. Whichever battery performs the best at 100% discharge, will perform best at 50% etc. The interesting fact is that they are all about the same, that is, because they are all basically the same battery. A Gel and conventional starter battery go down the same production line until one has a gel substance put in it and the other liquid. The shock with this figure is that for Gel, Sealed, or leisure, etc, the constant figure is about 30 – 60 cycles, whereas true traction with thicker plates is over 300+. (However, don't expect to see this graph on glossy literature, as they are way too frightened of this graph and will not release it). It is however available from correctly specked commercial batteries.
So which is the best battery for standard domestic leisure use?
The job I am referring to is for auxiliary charging systems on boats, camper vans or vehicles. I am not getting into what each and every battery type is best at, or for; as each type has a market, it just maybe not this market.
To pick the best battery for your job, then at least understand how they work. Forget the actual chemical formula and all the fancy terms around. The bottom line is that lead acid batteries have been around since the 1st World War and the basic principles have changed very little since. The only thing we all agree on is that they are not environmentally friendly, but are cheap to make and will remain king until such time as someone comes up with a solution which can compete. Which by the way to date they simply have not. How do I know this? Well it’s very simple, if they had, the lead acid battery would be out the door so fast its toes would not touch the ground.
So how do they work?
Let’s understand the basics. They are all lead acid, but fall into 2 basic groups. A starter battery and a traction battery (fork lift truck, true deep cycle).
Type 1 (starter batteries). A battery is simply a bucket of energy. If you wish to get the energy out fast, to start an engine (cold cranking rating) then you need a large surface area (large plate size). The only way to get a large surface area into the bucket, is to make the plates thin, so they can squeeze into the bucket (this is your starter battery; it needs the cold cranking kick in order to start the car, so its plates are thin to achieve this). This theory is pushed even further with batteries which increase this surface area more, to make what are known as high torque batteries. These deliver even higher cold cranking, by putting the plates in a 'swiss roll' configuration, in order to make them thinner and increase the surface area. This is good for cold cranking, but has a fatal flaw when it comes to fast charging. (The problem is, it works too well when charging and destroys itself).
Type 2 (traction or fork lift truck batteries). These batteries are not interested in the cold cranking kick, which is required for a starter battery, but are still interested in the power in the bucket. So they can reduce their surface area of the plates. The good thing about being able to reduce the surface area is that you can make the plates much thicker. The end result is you still get the same power from the bucket it is simply delivered at a slower rate.
So, for deep cycle and long life, the traction batteries are by far and away the best. But their price tends to kill them. However, if you are doing a long journey around the world, or going away from the UK for 2 years plus, then investing in 2 volt or 6 volt traction batteries is a must, regardless of the cost. They will pay for themselves many times over. For general leisure use they are the best, but a bit of a waste of money, unless you intend keeping the boat for 15 years to get the use out of them.
So what's the end result of these two battery types?
A battery is made up of lead plates, with a lead paste on the plates. Every time the battery is used, then so many bits per sq inch fall off the plates, if you have a large surface area then a large number of bits will fall off. Then to make matters worse your paste is thin so you cannot afford to lose the paste. However, if you have a small surface area and thicker plates the same is true, but the plates are thicker and as such, you can afford to lose a small amount of paste. In a nutshell, that is it, or be it in very simplistic terms, those are the differences between traction batteries and starter batteries.
As you can see from the above 2 battery types, the plate configuration cannot be blended. If for starting, you have a large surface area of thin plates, for traction you have a small surface area of thicker plates. One is black and one is white, there is no grey area. So, if you are purchasing a battery and it has a cold cranking rating and the salesman says it is a deep cycle battery, but will also start your engine; then it is in fact a starter battery (end of story).
What we want now is the best for general leisure
Having understood the 2 basic types then you need to ask yourself: what do you want from the battery?
Most people want
to charge their batteries as fast as possible in order to reduce their engine hours
to pay as little as possible for the above
to get about 5 – 7 years use as a leisure battery (2 weekends per month and about 4 weeks’ holiday per year).
If you are using your boat for leisure only, then stick to low cost lead acid so called leisure. If you want to turn your boat upside down for 5 seconds then the Lead Acid range with sealed removable caps would be a good choice.
If you want to turn you boat upside down for an hour or two then a Sealed Lead Acid would be worth looking at. However don't expect to charge them as fast.
Having had my so-called opinion published in a UK. boating magazine (boy, do Gel battery suppliers love me. I was taken off their Christmas card list), a Dutch magazine ran with it and the response was very good. The UK magazine did not follow up the article, however the Dutch magazine called ‘Zeilen' did. (The editor is Ruud Kattenberg.) They took the article and not only published it, but ran with it a lot of questions to their readers on their web page. They received over 500 responses and were able to confirm all my findings and published the results. (Not that I need any confirmation as we do this for a living, but it's always nice to have an independent source for folk who doubt you). Is this not what magazines are all about, trying to help the people who buy them and have a bit of a dialogue going?
Conclusion
The best battery to use for fast charging using advanced charging systems
For general leisure use: use low cost Lead Acid which can be topped up with water. So called leisure batteries
For long term cruising then use 6 volt traction
Avoid Gel / AGM for 3 reasons
very expensive
their fast charger rate causes them to gas
poor cycling numbers.
An interesting commentary. Yet I have to say that all 6 of Play d'eau's lead acid batteries failed within 4 years whereas their replacements (Lifeline 8-D 12v sealed AGM 255 Ahr) are still sling strong 10 years later....
I do have similar experience but believe it has more to do with the way they are used than with make or model. Good charging procedures makes a big difference.
The one i need to replace is at least 8 years old so not bad at all.
It goes without saying that batteries that are made below any fair quality standards can't be expected to perform on par with proper products. I once took a noname battery appart after it failed at the first -10C winter night. The plates were cardboard dipped in lead paste, fixed to to the cabinet by small plastic clips.
Im no expert on batteries, part of my day job is testing UPS systems doing routine battery discharges to see how long they last.
The UPS's are fairly large in capacity consisting of strings of 12v cells (in banks of 4 making 48/54v) each UPS typically has 6 strings, so 24 X 12v gel cells (each FAM155 cell is about £300 :-0 )
Anyway, what we have found is these gel cells don't like operating outside their designed temperature range. A slight difference in temperature kills them prematurely,
They don't like being transported, have to be very careful how you packaged them.
Some rectifier types seem to be more 'brutal' on the cells than others???
The design installation of the strings / inverter / rectifier system is crucial, having space for air flow around each cell helps with temperature.
Having said all that, we still get new cells which only last a year. I suspect it's down to quality control (or lack of)
I guess you're right. Temperature is crucial to most electrics/electronics and as stated in the article, the charge rate has a big impact on longevity.
Alone the heat generated internally when fast-charging is considerable.
That said, batteries in cars and boats actually like to be stored cold & dark, provided they are fully charged. This, btw. also prevent them from freezing.
I have to agree that charging is key. When changing the batteries in 2006, I also changed the charger to an 'intelligent' Mastervolt Chargemaster 24/100-3. I believe this has been key to the long life of Play d'eau's batteries.
Agree an "intelegent " charger makes the most difference by a country mile
Mastervolt , Victron and Dolphin .
With chains /strings or what ever -ie more than two batts connected then the actual conections are important -unequal L can lead to an imbalance and result in a deemed weaker one -which to cut a long story -brings them all down sooner than expected .
I,am not a fan of simpe wet lead acid as the topping up ,checking is just one more sods laws problem -sounds easy -but in reality -you tend to find the odd dry ish cell for too often .-and just top up -cos it still works !
Preffer sealed maintenance free ,Ideally just pairs .
There does seem to be an excessive number of batt probem posts recently on here .
We are very lucky to have the services an excellent boat electrician (who Sunseeker use ) in the SoF .
He knows what works and more importantly what does not ,
This kind of stuff -I leave to the experts
I pretty much agree with everything in the Sterling article
For bang for bucks, you simply cannot get better than good quality open cell lead acid (provided you charge and maintain them properly)
For economy and ease of use, bog standard off the shelf sealed lead acid leisure batteries do the biz
AGM and gel batteries simply don't stack up on a cost benefit analysis if you dig deeply into the numbers (beware snake oil!). In fact, the only practical reason for fitting either type is in situations where inversion has to be catered for. Blue water boats and boats coded for offshore work etc., yep go AGM or gel. Otherwise though they're expensive bling :)
If a bit of fred drift is allowed, I'm trialling DMFC (fuel cell) for a remote battery re-charge task. Simple Von-Voff set up, super low noise, methanol cartridges sized to suit. The cells are not cheap at a few £k each, but for no shore-power and essentially no noise battery charging situations with an opportunity to fit fewer batteries, seems to me as probable OEM fitout or on the option list before very long.
Once you have decided what to buy, a key point to obtaining good value is do not be fobbed off by the first price quoted. Like most things that fall into a so called 'Trade' category said trades will be enjoying 25 - 75% discount on the list price. The supplier is making his margin after the often obscene discount. If the Supplier can make a list price sale then he will be really happy, and once your name is listed as a punter it is then more difficult to get a trade price next time.t
So use a company name if possible when buying, you will rarely be questioned when you give your personal card details and address for payment, they just want your sale and still be able to claim yours was a 'trade' sale as far as they knew, should another of their trade clients complain.
This definitely works at Barden near Fareham. Applying this practice is perfectly legitimate, and indeed one thing with trade pricing structures that hacks me off is that this is a one way benefit for the trade client only - he remains at free to buy from any of a range of competing suppliers, yet the supplier is obliged to offer only him and his cohorts the discount, with nil guarantee of trade client loyalty.
I am in the process of buying a new Corian style worktop for my galley refit. Having been quoted £176 from one firm, I made another enquiry 'as though on a client's behalf of course', via my company email, where I shall now save myself 47%. In this case a little BS explains this is a trial use so possibly a one off also helps.
It has also gotten me a good discount from ASAP for years.
Actually, I wonder if its not the other way round - the discharging.
I wonder how many people don't watch the voltage as the batteries discharge.
In a standard installation, Princess don't even fit voltmeters.
Most of my knackered batteries have been due to discharging them too low - not intentionally.
I'm sure we are all to blame - we leave them discharging overnight and wake up in the morning to find the voltage low.
As the batteries get older, the overnight capacity drops and eventually we end up knackering them.
I also wonder how many people THINK their batteries are OK but don't actually do the test that the OP has done and see if they are really OK.
If all you do is leave the battery charger on with the boat plugged in, you may never know how good they actually are.
Is there a battery condition monitor that will give you an alarm when the voltage approaches a critical point? Something that will SMS you? I don't leave my charger connected when I am away from Rafiki. I had a "near miss" a couple of years ago, when one of the service batteries failed and overheated. I caught it accidentally before it went pop! In hindsight there were warning signs, as the charger fan was operating regularly, which was unusual, and I will be aware next time, but of course the engines need to be off to hear this. I have a Sterling smart charger, and this was unable to recognise that the battery was failing. I don't know if a Victron or Mastervolt would do so? However some form of thermistor attached to the batteries connected to a device to contact you in the event of impending failure, whether on board or away might give a bit of piece of mind?
a battery monitor from Victron (and probably Mastervolt aswell) can be programmed to give alarm when the state of charge is too low, (or below a preset treshold)
also when the voltage is too low it can give alarm, but imo this is MUCH too late to recharge,
when batt. voltage is below 12V, damage has been done.
I'm in the camp of keeping the boat connected to shore power permanently (during our absense)
we've been doing that now for 6 seasons of ownership of Blue Angel.
I'm more concerned that shore power is disconnected during my absense, and battery's are drained too deep (by the alarm systems...)
also at home, the trailable boat is permanently connected to 230V supply
a Victron charger has a small temp probe to "measure" the temp on the battery terminals,,
and automatically lower the charge current when the terminal becomes too hot, ...
(this is probably not what you are looking for Paul ?)
also I check all the battery's with a battery tester,
like this:
you have to disconnect each battery's on one terminal to do that measurement !
this tester does a test routine, and gives a quote of the condition of the battery,
its charge status, and its max capacity.
you have to preset the type of battery (lead, AGM, Gel) and the capacity of the batt. in this tester. The measurement is probably not very accurate,
but by comparing the figures from all battery's, you easyly find battery's that are bad, or start to be less good than the others.
I do this test right before, and right after the season, and has enabled me to detect "bad" battery"s and take them out.
all agreed !
like this:
Hi Bart, many thanks. Actually I'm more concerned about chatastrophic failure of the battery having had a close call. I had one too close to blowing up for my liking. I had a nagging feeling that I was due to check the water levels, and found one to be very hot. It took a couple of days to cool off after I took it out of the circuit. So it is temperature monitoring that I am interested in.
I believe the truth lies in the combinated charge/discharge metod as this is what makes up the cycles.
Depending on battery type and the specs given, the threshold for discharging can be 50%, 80% or something else. This is what to observe and, at the following charging procedure, allow the charger stages to complete.
Prices:
A brand leisure battery of some 100 Ah is about £115.
Expectedly AGM et al would be notably more expensive, but making a living from sourcing I had to make a competitive comparison for a valve regulated lead acid Vision 6FM100DX (AGM) Deep-cycle battery that uses a different chemistry for the plates active paste material, and a slightly stronger electrolyte than normal battery electrolyte, whick allows for a much longer life in deep cycle applications.
Weight is 32 kg so something must be inside the box!
The brochure recommends it for
• Solar Systems
• Wheelchair
• Golf Cart
• Marine Equipment
• Power Station
• Railway Systems
• Telecom Systems
• Cable TV Systems
• Emergency Power System
The offers for the exact same battery range from £160 to £367 !!
At an extra £45 on top of the standard leisure battery price I'm gonna reconsider the bussiness case :cool:
Prices:
Expectedly AGM et al would be notably more expensive, but making a living from sourcing I had to make a competitive comparison for a Vision 6FM100DX (AGM) Deep-cycle battery that uses a different chemistry for the plates active paste material, and a slightly stronger electrolyte than normal battery electrolyte, whick allows for a much longer life in deep cycle applications.
• Solar Systems
• Wheelchair
• Golf Cart
• Marine Equipment
• Power Station
• Railway Systems
• Telecom Systems
• Cable TV Systems
Also worth factoring in the operating temperature.
If the batteries are in the engine room (like mine) the temperature could easily exceed 40 deg C
And at that temp normal wet batteries struggle - All the sealed ones (includes AGM and Gel) don't work well and can become dangerous.
Thats my understanding.
Can this be confirmed? Lots of batteries work under higher temperatures (think road work in Africa and the like).
For the battery I'm referring to working temperatures are stated:
Discharge -20~60 C
Charge -10~60 C
Storage -20~60 C
Edit: The valve technology on these batteries is designed to release excess gas so not sealed.
Haven't measured temps in e/r where the batteries are but:
Summer:
28-29C seawater temp in touch with 1/3 of the e/r enclosure
35+C air temp in the other 2/3s of the enclosure
1.5-2ton of steel working to 80deg
I cannot imagine the e/r NOT being well into the 50s for 2-3h after the engines are off...
And on the charge/discharge discussion:
I feel that the solar panels have an extra advantage of making sure that when the loads are higher (throughout the day with fridges working overtime) there's a constant feed of Amps in the batteries reducing the unloading charge (actually should be minimising it from 10am-6pm). Then Led lights and cooler temps should help the batteries a lot throughout the rest of the night on to the following day!
heck, someone around here fitted a couple of 150-200W panels on a 35ft mobo and managed to squeeze a full size fridge freezer (don't ask, haven't seen the installation) with a small inverter and he's not even got a genny onboard! Spent whole summer with tons of ice and freezing cold food and fish on board...
Nevertheless I'll get the victron monitor Bart recommends for my service bank, plus the mppt and b/t dongle for the panels.
cheers
V.
