Battery Type/ Victron 15/75
Ink
28 Nov 2020
I have two standard sealed Lead acid 130aH Hankook baterries in parallel.
At the moment the solar MPPT controller is set to Factory default which is 'Gel Victron deep discharge (2)'
Can anyone advise if this is correct and if not what it should be set to? There is nothing in the paper work.
Choices Factory default are:
AGM spiral cell
Gel Victron deep discharge (1)
Gel Victron long life OPzV
Ink
AGM spiral cell
Ink
Use a custom profile, you need to enable "Expert mode" set it to: absorption 14.4v and float 13.4v
The current profile is 14.3v and 13.8v,which is incorrect for your batteries.
  • Like
Reactions: vas
Thanks, Paul.
Absorption is currently set to 14.4v and float 13.8v. Equalisation is at 16.2v but automatic equalisation is currently disabled.
I'll set float to 13.4v.
Thanks for your help.
Donald
