charles_reed
Ever since the AC Delco "Freedom" batteries came out in the late 70's I've fought (on boats at least) a losing battle with them.
One of the first Ca++hardened plate batteries, I found them reluctant to charge and equally reluctant to give up their charge. Add to that the curious charging regime on which ACDelco insisted (from memory, equalising @ 15.5v).
4 years ago a contact proudly supplied me with a 95AH Freedom battery, so far I've ignored its vagaries. Unfortunately the two battery boxes in the aft cabin only accept sealed battery sizes, otherwise I'd have an open lead acid as being much more long-lived, reliable and less expensive.
Yesterday I went into the aft cabin and checked battery temperatures, the Freedom battery was hot to the touch, it's next door neighbour just warm.
The layout is for two aft batteries (90-95 AH) feeding through a 1-2-both switch and a forward 120 ah open battery, in permanent use as a domestic. The two aft batteries take it in turn to be reserved for engine starting. Feeding into the live circuit is the input from a BZ500 MPPT controller fed by 3 pairs of PV panels, totalling a nominal 320 watts. Charging is via an Iskia 110 amp alternator (I've bypassed the Adverc) and a Sterling ProCharge 20, with individual feeds to each battery.
Today, after 18hrs with no charge and overnight, fridge use, batteries had fallen to 28C for all except the AC Delco which was 34C. System volts were 12.3 (not resting).
On turning on the charger it went into bulk mode (first time this year), for 61', it then went into equalising charge for 1:35hrs (it's set for 4hrs) and then onto float.
Maximum system volts reached 13.9 and on float 12.9-13.1.
Both MPPT controller and charger are temperature compensated @ #1 battery (the AC Delco).
At cessation of equalising battery # 1(ACDelco) was @ 54C, the #2 battery next door was @ 40C and the forward battery @ 33C. You must realise that in Crete ambient temperatures are 35-40C during the day.
When I checked the volts, after being rested for 2 hrs, disconnected, the #1 was 12.87 #2 12.94 and the #3 (in use) 12.54.
Any theories as to why #1 battery is overheating (there is a definite whiff of sulphuric acid fumes above the open battery-box, so overheating it is.)
PS I reckon to get 10 years out of the forward battery and 5-7 out of aft batteries - the latter start the engine and run the fridge compressor.
