The correct answer is only a few minutes. Your battery's 17Ah capacity will most likely be quoted at the 20hr rate. This means it'll supply 17Ah at a steady discharge over 20 hours (ie just under 1A discharge). If you try to take 33A (400W divided by 12V) out of it, it's capacity will be dramatically reduced. The actual reduction will depend on many factors, but you'll probably only get 15-20% of the theoretical 17Ah capacity - let's say 3Ah in round numbers. So the 33A current will flatten the battery in less than a tenth of an hour - around 5 minutes maybe.
