Battery splitters
rogerthebodger
3 Nov 2001
Looking through the Vetus catalogue I noticed that their battery splitter used MOSFET's in diode mode and claimed a volt drop of only 0.1 volt where the normal silicon diodes would have 0.7 volt drop.
Any one used this type of battery splitter and is this the case.
Having made splitters in the past for my previous boat using silicon diodes has any one considered making their own using suitable MOSFET's with a suitable sized heatsink
You would be well advised to fit an external regulator to your alternator (Adverc or similar) to give maximum charge and then there is no problem with diode splitters as the sense cable by-passes the diodes straight to the batteries.
Are these similar to the "X-Split" from Driftgate 2000"? I have fitted these to my last 2 boats and thoroughly recommend them, truly fit and forget. They claim 80mV drop @ ~ 100A, which seems about right, and are fully encapsulated. There is no heat sink, other than the body of the device, presumably due to the low electrical loss.
