Denis O
My Chaparral 180 has a 3.0 Litre Mercruiser and the battery has finally gone to the great battery graveyard in the sky, so need a replacement.
The dead battery is an 065 Numax 55amp with 540 CCA. As I'm tucked away on a Greek island battery retailers are like hens teeth but there is a Varta place. I went in and they did not recognise the 065 nomenclature so I came home and did a bit of research and found it's a Varta C11. The spec is 53 amp and 500 CCA so slightly inferior in performance to the dead 1. Not sure how much difference that would make.
My question is, would there be a better performing battery that I should use. Size isn't over critical as the battery tray has some flexibility but I wouldn't want to go way oversize. The current size is 242 x 175 x 175 mm (9.6 x 7 x 7 ins in old money)
