matt1
Don't you just love electrickery!
Have installed a BEP DCM Battery monitor (the shunt connected by pro's as they are heavy duty cables and I wired the "sense" wires to the monitor - its was fairly straightforward). I've not had chance to really see it in action before then installing an 110 w solar panel controlled by a Victron MPPT. Again, fairly simple to install (I may regret saying that after you lot have pitched in correcting me
The MPPT has Bluetooth and is indicating I'm typically getting 3amp charge when sunny.....but the battery monitor is indicating "-0.X discharge". Even on shorepower it is indicating discharge whilst the charger is showing "float". Indeed, whilst motoring under autopilot and with the instruments and fridge on the BEP was showing -11 amps discharge. The discharge values seem to correspond with what I would expect the charge to be. Anyone know what is going on?
Some values (all taken on a sunny day within a few minutes)
No shorepower, no solar, house battery off = 13.7v , -0.5 amps discharge (there are some always on circuits)
No shorepower, solar on, house battery on = 14.3v, (3.1 amps charge on Victron MPPT app), -0.7 amps discharge at the BEP battery monitor
Shorepower on, solar on, house battery on = 14.5v , (2.9 amps on Victron MPPT), -0.7 amps discharge at the BEP battery monitor
As ever, Thanks
Matt
As ever, Thanks
Matt
