rotrax
Much discussion in the past about this. Our chosen vessel has expensive OE Batteries, Lifelines. When we bought her in 2016 the batteries were 8 years old, but had been allowed to completely run flat by the previous owner. He changed 4, the engine start battery and 3 from the house bank. At the time, only 4 were available. The best of the discarded ones was used in the house bank.
As soon as possible after purchase, I bought a new Lifeline for the house bank. The old one, a 110AH job was fetched home to be used as a 12v power supply, jump starting a car and stuff like that. That was in late 2016.
I still have it, use it now and then. Tuesday I measured its voltage, 12.3v. I put it on a long - 3 day - trickle charge. This morning, after standing for 2 hours it read 13.1v. My heavy discharge tester, a proper garage one which gets bloody hot through the strip resistor, said it was very good. The needle stayed in the green after a five second test. After this five second heavy discharge it read 12.4v on a Wilkson meter. After a couple of minutes, 12.6v.
This battery has NEVER been on continuous charge. I see many boats in our club marina that have the charger connected 24/7 when on shorepower.
So, my discarded high quality Lifeline from 2007 is still offering good service. I know and appreciate the benifit of LiFePo batteries, but our current vessel runs two large fridges and a freezer 24/7 when we are cruising plus all the other stuff. The only charging for the batteries - 660AH in total, 5 Lifelines, I Chinese spiral wound AGM for the genset start battery, get their charge from the 400W of Solar through an EPever 30 controller and the Balmar engine alternator. The 60 Amp Charles built in charger has not been used since I fitted the solar.
Our previous vessel WAS left charging when hooked up to shorepower, the batteries were on their way out when we sold.
I believe you get what you pay for, Lifelines, in my long experience of batteries and practical LA Battery maintenance, are as good as you can get.
Steps back and waits for incoming....................................
