Battery for starting VP MD1
ghostlymoron
9 Apr 2005
Shropshire
What size battery do I need for starting a Volvo Penta MD1 engine? The manual doesn't quote a CCA, I don't think that rating had been invented when the engine was made! The engine is about 400cc - medium sized bike engine. Don't bother quoting red flash batteries, I'm not made of money.
VicS
13 Jul 2002
The Workshop manual for the MD1 specifies 60Ah max
The recommended battery for the very slightly larger MD1B is 60 Ah max.
A 60Ah car battery would be a good choice and more than adequate I suggest!
Nobody seems to be able to explain why VP quote maximum capacities
Plum
6 Jun 2001
UK East Coast
The "cold cranking amps" CCA rating of a battery is more important than Ah capacity rating for engine starting. Better to have a 40Ah battery with a 450cca than a 60Ah battery with a 300cca.
Colin. Www.solocoastalsailing.co.uk
ripvan1
20 Jun 2011
Pompey
Why is there a 60ah maximum - I've been using a 140ah varta and it starts within seconds, am I doing something wrong. While we're on MD1 I've found gasket sets from ASAP and Keypart but 1 set is twice price of the other - why is that. I can't find a thermostat housing gasket so suppose I'll need to make one unless anyone knows where I might find one.
bedouin
Are you sure it has a gasket? On the MD2B there is a little rubber ring round one section but no gasket
Tranona
10 Nov 2007
Car batteries have high CCAs - they are for starting engines. Any basic 60Ah battery recommended for a diesel would have no problem with a little MD1.
ghostlymoron
9 Apr 2005
Shropshire
I've always assumed the 60Ah maximum rating was something to do with the limited generation capacity of the Dynastart generator. (135watts)
scottie
14 Nov 2001
scotland
Max size batteries could prevent starter dynastarter burnout I believe was the reason quoted at the time
You may also recall that a dynastarter ran extremely hot just charging so that again could have been involved
VicS
13 Jul 2002
That could well be right although you will find a maximum capacity specified for later engines which had alternators not Dynastarters. 70Ah maximum for the 2001/2/3 series for example.
I've often wondered if it was to do with the high current that the battery could deliver to a stalled starter motor, a larger battery perhaps being able to deliver a current that would damage the motor, or the wiring.
