lumphammer
Following on from various battery threads I thought I would capacity test my batteries. My procedure was charge using Sterling Pro 30A charger till it went into float mode. Disconnect battery and leave overnight. Following day battery was sitting at 13.3 v off load.
Connect an ebay battery load tester similar to the ones used to test LFP batteries, I set it to disconnect at 12.2v (50% SOC) and as they are 130Ah batteries I used the C20 discharge rate of 6.5 amps. In theory I should have been able to come back 10 hours later to watch the capacity test finish, but in just under 2 hours the voltage had dropped to the 12.2v level and the test ended.
The batteries are just over 3 years old .
Am I missing something in my test procedure, or have my batteries had it.
We are full time live-aboard and the batteries are normally continually connected to the charger in float mode.
