Caladh
I am expecting to have to change the batteries on my yacht, based in Greece in September as I believe one or other of the house batteries are not accepting a charge. It maybe that the alternator is not working due to : - once during this season I managed to turn the ignition off and back on....don't ask. I also managed also to discharge the house batteries to around 11 volts this season .....don't ask !!
I have a Smart charging system set up with a 70 amp Balmar alternator. When the batteries are somewhat discharged I now only see a charge of 10 amps or less on my ammeter when I'm sure it could read up to 28 + amps (depending on how reduced the batteries were) initially, and then reduce as the batteries are getting charged.I have 2 x house 110 a/h batteries (and one 110 a/h start) and they are 3 years old. My last test before leaving the boat in July showed 13.9v at the batteries with the engine running.
At home now, I am still wondering whether the alternator is the "issue". Googling today I found this :
Testing the Charging System
Perform this test before removing the alternator from the engine.
1. An analog or digital voltmeter can be used, but the digital meter is best.
NOTE: Be sure to ‘0’ meter before making the test and that the boat’s battery is fully charged.
2. Connect voltmeter positive (+) lead directly on the battery positive (+) post, not the battery
cable ring terminal
3. Connect voltmeter negative (–) lead directly on the battery negative (–) post, not the battery
cable ring terminal.
4. Start the engine, increase rpm to 1300, and observe voltmeter reading.
a. Most systems will give a reading of 13.8 to 14.2 volts. Some gel cell batteries have
a lower voltage setting of 13.5 to 13.8v.
5. If the voltmeter is within range, leave the engine running, and switch voltmeter to the AC
volt position and observe voltmeter reading.
a. A reading of 0.25 AC volt or less while charging indicates the diodes are good.
b. A reading of more than 0.25 AC volt indicates that the alternator has defective
diodes.
I had not come across points 5a and b. before and wondered if anyone could state that this test WILL prove my alternator diodes are u/s ? Assuming that test is ok I could go ahead and order new batteries ?
Any help or guidance appreciated.
cable ring terminal
diodes.
