prv
Suppliers permitting, I should be installing Ariam's new battery system at the weekend. I've just been reading the manual for the battery charger I've ordered.
As well as the usual earth conductor in the AC input cable, and the common negative terminal on the DC side, it also has an earthing stud on the case. The instructions are most insistent that this be "grounded", but they aren't clear about how or to what.
I realise this relates to the minefield of galvanic corrosion, bonding of seacocks, IEEE standards, etc, but I'd be grateful for the forum's informed thoughts (and promise not to be too scathing about the inevitable uninformed ones ).
For information, the boat is GRP and is fitted with a saildrive that is electrically isolated from the engine. The only anodes are on the saildrive itself and the prop (which is isolated from the driveshaft) - there is no hull anode and no bonding of seacocks etc. The shore power system is also generally independent of everything else - currently it consists of a small consumer unit with MCBs and RCD, a couple of radials to 4 double sockets, and a connection to the calorifier element. The old battery charger was plugged into a socket.
So, connect the charger case terminal to the mains earth? To the DC negative? Both? Neither?
Cheers,
Cheers,
