Zippysigma
After replacing my batteries, I managed to short out one of the positive terminal leads to the engine whilst battery was switched on and engine running. (pulley chafed through insulation as I had not ensured it was routed correctly)
My battery charger CDM 230-50-12-08-2S would no longer show it's green "Tension chargeur" led. I found a fuse blown inside, so replaced that, but still no light.
When I measure the DC voltage across the output when connected to the mains, I get 12.5V, even with the battery connector switches turned off, so I wonder if it is actually charging.
What I don't know is whether the batteries would be connected to the charger, even if the battery selector switches are turned off. Can anyone help?
I guess that the obvious test would be to have checked this voltage when the battery charger was not connected to the mains, but I did not think of that until I started typing this :-(
The manual is in French, so just hoping one of you can shed some light.
Thanks.
Thanks.
