Divemaster1
All,
Need to replace my charger...
2x Battery Banks @ approx 220AH (Domestic and Start).
Came Across this one from TBB power, which seams good value..
http://www.capitalstores.co.uk/760-t11003-main-jpg
in comparison with..
http://www.yachtbits.com/sterling_power/sterling_24v_25_amp_digital_battery_charger.php
Both have the key elements of:
- steppeds charging curve
- recycle charging, getting rid of possible sulphation
- Isolated multiple bank output
- Simultaneously recharging and power supply
- DC Power Supply Function
- 110V AC and 220V AC
- protection against charger over temp, battery over temp, short cut, overload, reverse polarity etc.
- surge protector
- automatic temperature compensation with the temperature sensor.
Is thee anything else I need to consider in a charger??
Just seems silly to pay ot another £100 to get a unit from a "Marine" setup.. if it does the same job... or am I missing something??
Charger being replaced is a 30AH unit (unrepairable) that have lasted at least 15 years where the new one will be installed... relatively dry, at the stern of the boat and several meters away from the cabin, so not worried about noize from cooling fans etc.
- surge protector
