rigpigpaul
Hi All, how long would it take to fully charge a 400ah bank of lead acid sealed domestic batteries from half charge using a) 40amp battery charger or b) 90amp alternator. Thanks in anticipation RPP
Calder's yardstick is not to attempt to charge batteries beyond 80% SoC (state of charge) with an engine driven alternator because its so massively inefficient; the diesel energy consumed to power charged in to batteries ratio is bonkers. So I've adopted his strategy of having a high power alternator (120A) which bangs in about 90A typically (in bulk phase) and then as soon as I reach 80% and the alternator is going to absorption mode I shut it down. I then make sure that I get plugged in to shorepower every couple of weeks so that the charger can get the batteries back to full SoC. I've a 600AH AGM battery bank and went for AGM because of the high charge acceptance rates. If I do have to run the engine to charge the batteries I want to stuff power in as fast as possible and then turn it off!
Most efficient way to minimise engine use, is to charge up to 90% or so with the engine (with digital alternator regulator fitted) and then top up with mains/wind or solar.
I find this and similar threads interesting, having been working on charging system design almost 40 years.
Back in the 1980's / early 90's we never had a major problem with battery capacity or life, except the odd user. But as firms have bought out more advanced, and costly systems, so the problems people have with standard equipment has become a bigger.
Brian
