Battery charge
I have put a 2nd battery on my boat and found that now neither will charge!
I think it must be either
1 Switch (1 - 1&2 - 2 - OFF)
2 Knackered Battery
3 Alternator
The Anmeter runs at 12 volt when the engine is running ?!
Any one got any ideas?
davehu
27 Nov 2001
Portsmouth
Do you mean the Voltmeter show 12 volts, if so the Alternator regulator is duff you need about 13.8V minimum to get a charge into the batteries.
halcyon
20 Apr 2002
Cornwall
If the anmeter is a voltmeter, the alternator is shot, should be above 14 volt.
Regards
Brian
