sona
Active Member
I have a Sun Odyssey 24.2 with 1GM10 engine with standard 35A alternator and single battery of 70AH (6 years old but not giving problems).
When sailing I am using speed/depth instruments, vhf and chartplotter with the intention of installing a tiller pilot.
I an concerned that the battery will run down and cause engine starting problems. Should I install a second battery either in parallel or seperate with changeover switch (space would be a big problem), or replace the single battery with a larger capacity battery?
