Keithleask
Have been having issues with battery charging etc for quite some time now with the domestic batteries. Looking at how all three banks are connected, 2 domestic batteries and four for the two engines I notice that the four batteries for the two engines are wired back to my newmar abc 12-40 amp three bank charger. The charger has a common neutral and three charging leads but these charging leads only go to the engine starting batteries. Alongside and part of the charger is a finned like metal connector block that has returns from the batteries, 6 number, from this connector block 4 cables go to both alternators. Question is how do the domestic batteries receive a charge if they are not connected to the charger?, I am thinking the engines need to be running to put a feed back to the connector block which in turn supplies a charge to the domestic battery . Does that sound correct? If so then it means that if the boat is standing for any light of time the domestic batteries will run down? Is that right?any help greatly appreciated!
