wotayottie
Likely a daft a question but I want to be sure.
Batteries arrive with acid in them and you can measure their degree of charge with a hydrometer. Now I have installed an !advanced regulator" and the leaflet with it warns that thiss means more gassing and the need to top up the batteries. So I topped them up.
But if I have done this too generously, it seems to me that the specific gravity of the battery acid will fall, the hydrometer will then indicate that the batteries are discharged when in fact they are fully charged.
If this is not the case then there really is something odd going on. At the moment with no engine going my batteries are reading 13.6 v after a 2.5 hour run with the charger belting out 14.4 volts. So they should be charged but the hydrometer says they arent.
Any fault in this logic?
