snowleopard
batteries - what is \'equalisation\'?
i have heard that a sulphated battery can be revived by overcharcing for a few hours at around 15.5 volts, causing heavy gassing. i believe this process is called 'equalisation' and some battery chargers have a cycle which will do this.
i asked Sterling if theirs did and was told yes.
having bought the sterling charger rather than the more expensive dolphin i find out that it doesn't have the programme i wanted. they say equalisation is just another word for 'absorbtion' or 'bulk' charging.
where did i go wrong?
while on the subject of batteries, the absorbtion charge voltage can be set to 14.4v for gel or sealed batteries or 14.8v for standard lead-acid. mine are 'maintenance free' lead acid, i.e. normal batteries which don't need topping up - would you call these 'sealed'?
