Base & Cap needed for Series 40 Aqua signal Tri/Anchor Nav Light
jt_MG Spring
New Member
2 Oct 2010
Fellow boaters,
Do you know where I can source a replacement base with or without the cap for this type of aqua signal nav light? or if any body has a spare they no longer require, then I would be most greatful. e.g. supplied with a replacement after losing a light perhaps, and the original base was re-used.
Happy to purchase the base for the going rate, plus postage etc.
please drop me a private message.
It is the the clip on type I need (2 lugs on either side), not the newer screw on type that is similar to the lens body attachment.
Many thanks,
JT
Fellow boaters,
Many thanks,
JT
Unlikely you will source a replacement base/top. Lenses are available but usually cost about 70% of new light cost.
