Nicholas123
N/A
I have got my eye on a boat that has got one but I have heard terrible scare stories about them.Can they be trusted & what are the pointers to look out for?
Any advice welcome.
Any advice welcome.
Any advice welcome.
There are two potential issues. The first is a failure of the bond between the balsa and the GRP skins which manifests itself in springiness of the panel. Most obvious in large flattish panels such as foredecks. The second is water absorption through poorly sealed fittings, although many builders try to bolt through fittings in solid areas. As already noted, screwed on teak decks are probably the worst potential offenders.
Cored decks are very common, so surveyors know how to spot potential failures.
If you're looking at the cheap Arpege the deck is less of a worry than the osmosisThere are a few threads on here about this boat although I think someone is in the process of buying it?
The most common cause of damage I see on balsa cored decks is the use of sealant only.
Any and all holes should be drilled oversize and filled with a mix of epoxy resin and Micro-fibres then re drilled to the required size after curing.
This protection for balsa and support the added stress if thru bolting.
When thru bolting it's also important to spread the load by adding more Micro-fibres and resin between the backing plate and the underside of the deck.
Also note all backing plated should have well rounded corners on ALL edges.
Good luck and fair winds.![]()
Sounds complicated & clearly I am going to have to get a book out the library if I acquire a boat with a balsa core.
It has occurred to me that you can probably detect trouble by tapping the deck with something like a light wooden mallet.A sound deck should give a good resonance where as a dodgy one would give a dull thud?
Sounds complicated & clearly I am going to have to get a book out the library if I acquire a boat with a balsa core.....
I understand that an Arpege has no main bulkhead. So if the deck has no strength in it, whats keeping the shroud base apart? Probably worse than osmosis....
That's a good start, but if the price is anything significant, you do need a surveyor to run a moisture meter all over her...
It is possible to repair rotted balsa cored decks - there are some commercial solutions around - but it is expensive and a lot of work - particularly if you want it to look good when you've finished.
Better than the library, why dont you download your own Fiberglass Boat Repair Book. A very useful book I have found. Good for most GRP work and certainly includes balsa cored deck repairs.
Thanks for that advice but I am unlikely to afford a surveyor.Might have a crack at buying one of those water meters on ebay if my infatuation with this particular make & type of boat persists.
