timmygobang
Who's got them? and do you live in constant paranoia that your boat is going to turn to mush? Or do you spend your days re-bedding stanchions and deck fittings wishing you had made a different choice?
Agree entirely that the problem is what previous owners have done... Many years ago I had a small boat with sodden balsa coachroof top, which I did eventually fix, but a horrible job. No obvious sign until I drilled a small hole up into the inner skin to fix a light, and water poured out! On tracing the leak I found several badly bedded fittings topside.I've had one, a Lightwave 395.
Never had any issues with core rotting, but these boats were better made than some, being vacuum bagged when built.
I did have some issues with the skin coming adrift from the core where collison or mooring damage had been poorly repaired.
You are at the mercy of previous owners IMHO.
I'm having a guy drill holes to inspect exactly this as a requirement prior to purchase as there is a degree of delamination above normal on the coach roof of a boat I'm looking at.
I must admit that once I have chosen my next boat, first question would be to find out if the hull is Balsa Core. Until recently I had never heard of this method of construction, I certainly thought that hulls were GRP all the way through. I was talking to a Powerboat Instructor who mentioned this method of construction and he was wondering if when a boat hull flexes the outer thin GRP could come unglued from the balsa core and then start to wear with constant flexing.
Time will tell. (But not with my money)
Whoops that should read Hull and deck !!
As already mentioned most boats have a balsa core deck - good practice is to cut out the balsa and have plywood or similar inserts in the way of deck fittings etc
