CharlesM
Hello All
I have just purchased a Balmar MC-264 regulator and wish to use it to control 2 alternators of identical capacity.
I spoke to Balmar tech support, and apparantly I need only splice into the field wire at the regulator and take that to the second alternator. - in addition I simply change the 10 amp fuse to a 15 amp fuse (my system is 24v)
My question is how do I go about wiring in the warning lamps which are usually near the engine switch, and which generally go out when the alternators start producing a charge. Should I have only one bulb, or a bulb for each alternator?
Wiring the system without bothering about the bulb seems rather simple, but adding 2 bulbs has me baffeled.
Looking at the manual for the regulator (see http://www.balmar.net/PDF/MC-624%20Manual.pdf ) on figure 3 has a terminal lables ALARM (DASH) - would this be the other pole to attach the light to, and the other end of the light attaches to the ignition? If this is the case then there will only be one light rather than 2 (ie: a light per alternator)
Any advice would be much appreciated.
Regards
Charles
Regards
Charles
