[2574]
I've a new Balmar 70A alternator which is regulated by a Balmar ARS5 regulator. Fitted last winter. This summer I noticed that our engine (Yanmar75hp), whilst running at low rpm, was constantly changing it's tone, I thought it was fuel starvation or some other mechanical problem as the change in engne sound was positively noticeable. I checked filters and suchlike. Then I happened to notice that the output from the alternator was fluctuating between about 15A and 50A every second or so. The change in load from the alternator was sufficient to change the tone of the engine.
I've been in contact with Balmar and so far they've not been able to provide any guidance as to what the issue might be. It's been suggested that I increase the float voltage but I don't fancy that as it'll cook the new 750AH AGM battery bank. So I'm at a bit of a loss and on the point of swapping out to a different alternator, perhaps a Wakespeed, undecided at present.
If anyone has any experience of anything similar and can provide details of if/how it was resolved I'd be very grateful to read the details.
If you can bear it here is a dropbox link to a video showing the fluctuation of the amperage/voltage as seen on my Victron power monitor. 20220923_151253.mp4
