[2574]
How best to lubricate? The boats being lifted in two weeks and I need to get the valves moving again or I fear its seacock replacement time. Any brilliant ideas?
TIA
Rob
TIA
Rob
TIA
Rob
Grease not much use on ball valves as they are stainless balls running in composite bearings. They are stiff through lack of use so deposits build up and prevent the ball from moving. Can usually be shifted by putting penetrating oil down from the inside and spraying from the outside. Good lever on the handle will also help, but handles are mild steel and can corrode. May need a bit of persuasion but once shifted should be OK. Avoid jamming by regularly operating. However I have just taken one out after 17 years and it works perfectly even though it was left open most of the time.
Hmm not quite right as many ball valves are made from composite nylon/plastic. Only use marine grease.
Peter
I was told something this year that I hadn't appreciated. In the case of valves with a metal ball, the valves which are kept open don't get problems whereas the ones kept shut do, as the exposed metal corrodes or gets accreted, forming a rough surface that doesn't move across the plastic or whatever. This seems to be my experience, as valves such as cockpit-drains remain smooth, though I try to exercise them all regularly.
