baggy mainsail question...
causeway
12 Jun 2012
My main is terribly baggy, especially on the section closest to the luff.
When I put the flattening reef in It looks pretty good.
Can I just take the bolt rope out of its slot and use the flattening reef points and make the sail loose footed?
Any dangers in doing this? I'll be using a set downhaul and adjustable outhaul. If that makes any difference.
Many thanks
europe172
2 Sep 2007
You could just try to see if it works for you, you will never know if you just listern to advice, have a go and report back :)
lpdsn
3 Apr 2009
Try a bit more halyard tension. If you end up with wrinkles parallel to the mast, and they're still there when you've trimmed the sail in, ease off slightly.
causeway
12 Jun 2012
No matter how I tension it, the bagginess is severe. It takes the 'depth' out of it when I use the flattening. It just looks like a well worn sail instead of a fully blown one. Scheduled 20kn gusts tomorrow so a flattening reef might be a good idea anyway!
Daydream believer
6 Oct 2012
Southminster, essex
Many thanks
The bolt rope will still be the same length whether in the boom or not so will probably do nothing. But as others have said - try it
Lakesailor
15 Feb 2005
Near Here
Is it a conventional bolt-rope? It may have shrunk. Can you unpick the bolt-rope at the head and try hoisting the sail. If the creases have gone you need a new bolt rope.
This was my old sail with a shrunken bolt-rope. The other is a new sail.
causeway
12 Jun 2012
I think that is exactly what's happened. Some of those characteristics are shared with my sail.
How much would it cost, roughly, to have a new bolt rope sewn in? Bearing in mind it's a fairly tall masthead rig.
John the kiwi
23 Nov 2011
Nelson New Zealand
Try and find a local well recommended sail maker and get him to view the sail hoisted, then take his advice on repairs.
My sails used to look like the "before" photo above, but for about 10 % of cost of new sails spent on adjustments by the sailmaker, they now look like the "after" photo. Not quite as white though!
The boat sails better and flatter and i have deferred a new main until next season or maybe the one after.
