Has anyone recently taken on bad fuel in Plymouth, I took delivery of a new motor boat in March 2003 and have only filled up at 2 locations in Plymouth since then. We recently experienced problems with our engine (lack of power, inability to achieve high revs,smokey exhaust) and had a scarey time trying to get back to Plymouth from Salcombe with engine revs dropping from 3200 eventually to 1200rpm. After arriving back at our berth i changed the filters, the primary filter being full of a black thready substance, This appeared to have solved the problem but after only 3 hours the primary filter was as bad as before. I approached a local marine engineer who offered to inspect the fuel tank and if required drain the fuel, replace the filters and clean the tank. His report was astonishing, he reported that the tank was very heavily contaminated with dirt and sludge and due to the age of the boat it could only have been caused by taking on heavily contaminated fuel. The tank was removed and steam cleaned before being reinstalled. Has anyone had similar problems in Plymouth?
<hr width=100% size=1>Spinnaker
