tome
I have a very nice Navtec backstay tensioner which I haven't yet fitted. My rigging is 10mm which suggests that I should have the -22 model which is indeed the model I have, see short handbook.
Problem is that I've wound back the max pressure as far as I can and it still allows it to be pumped up to 3000 psi which equates to a tension of 8400lbs. The breaking tension on my rigging is 19,425 lbs. So almost 45% rig tension is possible given a careless crew or a gadget fiddler.
My main worry is on the tension on the forestay if someone should do this. Since the backstay makes a wider angle with the mast, the forestay load could be 1/3 more or 60% if this happens.
Is this an accident waiting to happen, and if so how could I prevent it? The safest model appears to be the -12 which I could limit to a safe load, but this specifies a max wire size of 8mm in the handbook.
Will talk more to Navtec but any thoughts welcome.
