skyflyer
Newbie question. I have only recently bought my own boat having previously rented etc. On previous boats I cannot recall seeingany issue with the bowl of the toilet backfilling - clearly seawater coming back from the outlet - provided the lever (Jabsco) is put over to the right hand side.
Other people have advised shutting off the outlet seacock every time we put to sea, but it is not that easy to get at, and of coure prevents use of the toilet when underway! (Not ever ideal, but sometimes ..just necessary!!)
Having studied the diagrarm in the manual and also a pack of spares, I see there is something called a 'Joker valve'. This seems to be like a tricuspid heart valve, ie the back pressure should seal it from back flow.
My question is, is it worth replacing this or is there always sufficient 'back-leakage' to allow a small trickle backwards. I dont really want to do what could be a pretty unpleasent job unless it is likely to make a big improvement!
By the way, the effect is worse when on a port tack, ( toilet is starboard side)
Any advise from you nautical sanitation experts would be handy!
Cheers
Cheers
