pagoda
We have inherited three 20/20 remotes at the mast. Two work OK the other flickers. I dismounted it and brought it home recently to investigate.
After carefully prising off the back/cover joint it looks pristine inside- no water/moisture damage. - nothing much amiss. Parked it all on a radiator for 24hours and did some checking.
With only power, it displays "Battery..**" nothing else. I don't have a Fastnet network at home to do more testing. I discovered the yellow core inside is part of the "remote button" option - which also allows basic diagnostics . Grounding that during power up did nothing different? Should have?
Any clues ? Or just send to aandtinstruments?
