Astralis
Hi all, has anyone replaced the worn out flock lined window channel that Azimut use on the quarter moon electric opening windows and if so where did you get the channel from?
Both my windows channel have lost their flock finish and now the windows struggle against the bare rubber. I often spray with silicon oil which helps but would like to replace with new. Now the problem I have found is not being able to track down a profile or size the same as the original, anything coming up searching generally is for car use and is either to small or for thinner glass than the 6mm of the Azi windows. Any suggestions or help much appreciated, cheers Simon
