Avon repair
Billows
31 Aug 2010
Firstly can someone identify model and age?
Secondly it leaks water under the transom.The black seal inside is split along its length which I suspect is the problem.Any suggestions for how to repair?The red valve surrounds were put in when the valves were changed, not original.
The Avon is Made of Hypalon so any patching you do to the transom make sure you use Hypalon material and two part Hypalon glue. I have always found www.rib-shop.com a great place to get repair products.
