frothblower
Hi all,
The marine ply pad on my auxilary outboard bracket is starting to delaminate and looking worse for wear and id like to replace it with a white plastic or nylon that will not only look nicer but also last longer than the wood.
Could anyone advise what material would be suitable to hold the weight & thrust of the engine and also hold up to the UV?
Engine is a 2.3hp Tohatsu 2-stroke and weight is only 10-15kg. Its not mounted on the bracket perminately, emergency use only.
If anyone has done similar and could recommend material and or a supplier/link would be appreciated.
