davierobb
I have a VW Sharan with an auxiliary diesel heater fitted under the back passenger side seat. The heater is diesel powered, heats water and subsequently heats the rear of the car up via a self contained heat exchanger. The heater unit is very small.
The setup looks ideal for a small boat, power usage for the fan might be a problem but no different to eber and propex units. I guess that these units are readily available from scrappies, has anyone tried to use one of these on a boat and did it work ok?
Also, it might/should be an easy job to use the engine cooling water to feed unit when engine is running.
