Hunter34
I need to buy an autopilot for a full keeled 11.5 tonne cutter that has mechanical wheel steering and a centre cockpit.
According to all the advice I have read what is needed is a below deck unit which attaches directly on to the rudder quadrant which is linked to a computer unit and finally to a control head all of which is 4 times the cost of the biggest wheel pilot.
I use an ST4000+ on my boat which copes fine whatever the weather and has managed over 9000 miles over the last 3 years.
The cutter weighs twice as much as my boat but the steering is no heavier and is still 2.5 turns lock to lock.
From what I hear full keeled boats as supposed to hold a steadier course than us narrow fin keelers so the wheel pilot should have less work to do.
Also with having a centre cockpit surley a wheelpilot will keep drier than in my aft cockpit.
I know the ST4000+ is only rated to boats of around 7 or 8 tonnes but if its operating conditions are better than that on a lighter less stable boat I cant understand why on shouldnt be used on something bigger.
Also as far as I can make out the reaction times and speed of the below deck unit and the wheel pilot is the same.
True the thrust power of a below deck unit is more but it would have to be if it is attached directly onto the quadrant.
Or am I wrong.Do full keeled boats need more work to hold a steady course, tear the wheel from your hands when the weather turns nasty and constantly have cockpits full of briney.
I dont mind spending the extra money on a below deck unit if I know that its necessary and worth the extra.
If its just a case of the wheelpilot is only expected to last half as long as a below deck unit I would just buy 2.
Any thoughs much appreciated.
Andrew
Andrew
