Goldie
I need to replace the autopilot pin which is tapped into a steel arm on the rudder quadrant. The pin will be threaded on the lower portion with a ‘spacer’ with machined flats above the threaded portion for tightening. I have a friend with the skills and machinery to produce it, but what is the best metal to use please? I believe that ‘ordinary’ SS is liable to fracture so is there a best grade to use, or should I avoid SS completely? If the latter, what is the best metal to use please? The pin will be approx 12mm diameter and the pilot is a hydraulic ram on a 40ft boat displacing about 12 tons in cruising trim.
Knowledgeable replies would be really appreciated please. Many thanks in anticipation.
