Whitelighter
So after two solid days of doing jobs on the boat I know have a working autopilot.
The bad news is the pump sounds very unwell. Unusually it's a constant running high volume hydraulic pump, rather than a type1/2/3 reversing pump.
I'm not sure why ferretti used this type, the singe steering ram looks smaller than the max 500cc for a type 3
Anyway, when the pump is running it is producing hydraulic pressure and turning the steering correctly but it's making a loud (audible at the lower helm loud) graunching noise, like bearings rubbing together. I assume theses pumps should be silent?
Does anyone know a) which side of the system (pump or motor) is likely to be making this noise and b) if either side can be reconditioned. New the pumps are £2100 and even a non-genuine one is the thick end of £1800 so I'm keen to try and find a cheaper fix if possible.
