Yellow Ballad
Does anyone know a source for the large two pin dri plugs that come on tillerpilots? I want to replace mine with the same design if possible.
Do you need the plug, or the socket Tom ?
I have a couple here, let me have the diameter and if it's the same you can have one for the cost of the post.
Hi Paul, thank you for your kind offer, I need both so I think I'll take Poignard up on his unused set.
@PaulRainbow Do you still have the Dri Plug? I bought an old catamaran with the 2-pin Dri Plug socket fitted in the deck, and I can't find a plug anywhere in the UK.
Many thanks if you can help - 07576 076428
James
If you can't get the same, you might consider Bugin Buccaneer, which is what Raymarine & Pelagic use.@PaulRainbow Do you still have the Dri Plug? I bought an old catamaran with the 2-pin Dri Plug socket fitted in the deck, and I can't find a plug anywhere in the UK.
