Autopilot advice
Elena2
New Member
22 Sep 2009
Essex and Turkey
Hi fellow Motor boaters,
I have a Raymarine ST7001 autopilot system fitted to my Aresa 16 meter and I want to fit a repeater to my flybridge. Can anyone help me as to what Raymarine head unit I will need and how it is connected to the original system?
Many thanks in anticipation,
someone may have the answer, but Raymarine have a pretty good support desk, so you could always ask them !
Dunno, I have a repeater on my ST 6001, all supplied at the same time. As above. Ask Raymarine.
You can fit an additional controller by simply connecting it to any where on the seatalk system, I fitted an extra controller last week and it came with a 9m cable, you will need to find out which course computer you have to find out which controllers are compatible althou most will work depending on the age of the unit. All the calibration will already be done with the existing control so ignore the sticker that says to calibrate before use when connecting as a repeater.
Hope this helps, if you need further help then you can pm me
