Autohelm compatibility
stevesales
30 Dec 2004
Nicaragua
Does anyone know if the Autohelm 100 computer can replace the ST6000 - ie will work with the 6000 control unit, fluxgate, rudder transducer and motor ?
Shanta
25 May 2004
Spain
Would you like to elaborate on Autohelm 100 ? What does your manual say it is called ? What colour is you ST6000 head (control) unit ? No this is not a trick question.
pvb
UK East Coast
It should be compatible...
The Autohelm 100 computer should run on SeaTalk like the ST6000. You'd need to check what type of drive unit you have - the 100 computer only has enough power to run Type 1 drives, more powerful drives need the 300 computer. You could try looking at Raymarine's question & answer section and, if you can't find the answer, there's an "Ask Raymarine" tab you can click on to send your own question.
Ships_Cat
7 Sep 2004
Re: It should be compatible...
Agree entirely and add that the 100/300 manual which is on the Raymarine internet site (forgotten the title of the manual) also clarifies which computer is required for which drive.
John
