Autohelm AH800 socket
mbay
3 Jun 2003
North East England
My AH800 packed in yesterday, on closer inspection its the socket not the unit itself its rotten, does anyone know if its possible to get hold of the old 2 pin type socket?
As I've started to sail mostly singlehanded so I need a Autohelm and have thought about buying a whole new unit and keeping the ah800 as a spare but i'll still need a socket for it unless i can knock something up bespoke as anyone done this?.
Probably not worth chasing after a like-for-like replacement, any polarised plug and socket will do the job (so long as it's water resistant). If you're going down the path of a new unit with the old as a spare, then get a spare plug the same as the new unit and fit it to the AH800. I did this with an old ST2000 when I bought a new ST2000+.
Rob.
Of course, DOH!.......... it is very early in the morning for me
FWIW my AH 1000 (old analogue type) is connected by a "Driplug".
If you use one a smear of silicone grease on the sealing O ring makes it easier to plug in and unplug again.
For a 2 pin connection, I'd go with VicS's suggestion of a DriPlug. If you buy a new autopilot, I think they come with a 6 pin plug & socket, from the Bulgin Buccaneer range to allow for NMEA and Seatalk connections.
You could either buy a 2nd. Bulgin plug for the AH800, using just 2 power pins, or change to DriPlugs on both A/H's.
