Richard D
Probably been said before but was having problems with the belt not gripping on the auto pilot drive wheel mounted on the main steering wheel, all the eration had worn off due to constant wear, solution get an old drive belt and stick it teeth side up so that teeth on the driving belt match up and act as a pair of gears, only thing you may need a bigger diameter belt as the fitting of the belt onto the wheel hub increases the diameter and so a longer belt is necessary unless you have plenty of adjustment. Belt stick well to alloy hub after cleaning with thinners or similar and stick using sikofle or similar.
Richard
Richard
