FrankJB
I have a continuing problem with the automatic bilge pump on my LM 27. The LM 27 has a smallish sump in the bilge under the engine that probably holds about 5 litres of water.
Last winter I fitted a Sahara S1100 pump, which has an integral float switch. The problem is that because the sump is so small the column of water in the outlet hose runs back into the sump once the float switch tries to stop the pump restarting the pump starting a continuous loop!
A non-return valve seemed like a good idea so I fitted one as close to the pump as possible. This sort-of works but these valves do seem to leak especially when they suck up a bit of debris and they do restrict the free flow from the pump.
I can see that raising the pump in the within the sump would probably solve the problem but that would mean more water sloshing about in the bilge!
I’d be very grateful for any other ideas or solutions.
Thanks, Frank
Thanks, Frank
