Peter
Got to attach 4 pads, to sit the tender on, onto the coach roof, which is GRP sheathed over plywood. For reason of ascetics with the interior of the roof I do not want to screw or through bolt the pads. So I want to “glue” the pads to the roof, either with a standard polyester resin which I’ve got, or epoxy, which I have none. As the pads are fairly small, approx 50x 100 each I’d prefer not to go to expense of buying a pack of epoxy for this job. I am I OK using polyester resin, will it gives a good bond or is epoxy the way to go.
Thanks for your answers
Peter
Peter
