Astronomical Brain-Teaser
Gary Fox
N/A
31 Oct 2020
Pinched from gCaptain, the answer is obvious when you don't think too hard..
You are standing on a hilltop and, at sunrise, you aim your sextant at the middle of the Sun. This forms a line.
You return to the same hilltop at noon, and again aim your sextant at the middle of the sun, forming another line.
Q: Where do these two lines cross?
Since both lines go from where you are standing to the middle of the sun, the obvious answer is "Either where you are standing or the middle of the sun, depending on the axis system used".
……… when you don't think too hard..
I’m probably guilty as charged. ?
I don’t understand the context of the question. It seems superficial to the point of being either misleading or wrong ?
No mention of (artificial) horizon. Why use a sextant to obtain two bearings, why not a simple compass.
Why aim at “the middle of the sun”. A position line derived from a sextant angle (position circle of infinite radius) will be at a tangent to the bearing of the sun. No mention of any sight reduction.
A local noon will always be due south, in northern hemisphere, and sextant angle will enable latitude to be derived.
The simple question is too vague and confusing for me, yep, I’m probably over thinking it ?
Surely the lines only cross at the centre of the sun? Your position has changed in the time between sightings (due to earth rotation on axis and earth orbit around sun). The only point they both go through is the sun
Yes, the starting points of the two lines will be a quarter the way around the earth and the lines diverge at the earth.
